Hello.
I wanna design, build, and persentation plane like that's
would tell/share anything about that's!
Thank you so much...
I am looking for something like that as well.
Only three propeller for the lift and an impeller for the push integrated in the fuselage. If you use a tailplane you will produce to much drag.
The main Vtol propeller should be in line with the CG and the back propeller controls only the movement of the axis.
best regards
