What type of meshing I can use for Beam?
How many types are there?
Method of meshing?
Beam can be analysed by 1-D,2-D,and 3-D idealizations.
1-D line meshing is sufficient by defining Cross Section in real constant set.
2-D Plane stress idealization Plane Element (Quad and tria second order.Donot go for linear Triangle elements as they give you less accurate results.In case if u are going for them Refine the mesh at the region of fixity or the region of stress
3-D All solid elements.
I have 3D model and I am trying to mesh in ANSYS workbench.
So in that software what option i have to use.
Select Mesh Method there u will get options to Select,Sweep ,Hex dominant ,or Tetrahedrons.U can select from there.Go for Complete Hexa mesh from Sweep and all hex elements.
