I want to draw a pivotdoor, how should i do this?
I drew already the pivotpump in assembly.
I also drew the invirement in assembly.
I want to open and close the door.
I build up in 45 x 10 mild steel.
Do i make the door in part or in frame generator?
Thanks
F.
Hi Frederich!
I'm not sure if I understand what you're asking, but if your intention is just to make the door rotate, I can tell you that it's simply a matter of knowing how to use the Inventor constraints, but if you want to do all the technical drawings as well, it takes a bit more info and description to understand it all.
Finally, as regards whether to make the door in part or in the frame generator, this is indifferent in my opinion, it depends on the complexity of the door, and on the executive technical drawings for the construction that you want to have in order to be able to print and make in the workshop.
Hi Tani,
Thanks for the reply!
I want to do it good, so i need to draw every part seperate ( i think?)
i want a drawing , i can give to everybody without explain things. With a Bom list that tells what is needed to make the door.
But i feel that is a hell of a job, i think it is more easy to draw the door in part.
Hi Tani,
OK, these are statements on your part.
Unfortunately, not being able to speak English well is a big failing on my part,
please ask me specific questions.
If, on the other hand, you need someone to help you out with the design, I can try to help you out as I work online as a Freelancer on some of the best known platforms such as:
The links above take you directly to my profile pages where you can hire me. Don't worry too much about the price, we will definitely find an agreement.
Tani,
I am a beginner, so i will try some things first.
If i get stuck, i will call for help.
Thanks
F.
OK, I understand, ask me whatever you want, I'll help you if I can, just try to be as explicit as possible please.
Hello, visit my profile, my last model contains a Pivot Fence for a window. Check it!.
Greetings.
