this is the Error, please help me how to resolve them
TAPPI HAM HANG TRUOC.ipt: Errors occurred during update
TAPPI HAM HANG TRUOC.ipt (Flat Pattern): Errors occurred during update
Definition1: Could not build this FlatPattern
Error querying the Bend Table. The angle or radius are outside the table boundaries. The input values were: Thickness: [1.200 mm], Angle: [2.38 rad], Inner Radius [1.200 mm].
Error querying the Bend Table. The angle or radius are outside the table boundaries. The input values were: Thickness: [1.200 mm], Angle: [2.27 rad], Inner Radius [1.200 mm].
The attempted operation did not produce a meaningful result. Try with different inputs.
