⭐ 𝑬𝒍𝒆𝒄𝒕𝒓𝒊𝒄 𝒄𝒂𝒓 𝑫𝒖𝒃𝒊𝒏𝒂 𝑬𝒗𝒐 ⭐
Created by Dubina on 2 October, 2024
Project from 3D constructor - https://dubina.biz
The control block is an electronic device responsible for monitoring and controlling various systems and components of the car. It plays a key role in ensuring the correct operation and interaction of various components of the car. The control block monitors the engine. Regulates traction on the wheels to prevent slipping and ensure the stability of the car while driving. Responsible for preventing wheel locking during braking, ensuring the stability and controllability of the car in difficult conditions. Controls body functions such as central locking, lighting systems, rear-view mirrors and others. Regulates the operation of the heating, ventilation and air conditioning system. Controls the navigation, audio and multimedia system. The control block contains a microcomputer. It is a small board slightly larger than a bank card. A specialized distribution is used on the computer. The board is based on the Broadcom BCM2711 SoC, which contains four 64-bit ARM Cortex-A72 cores with a clock frequency of 1.5 GHz. The computer has 8 GB of LPDDR4 SDRAM RAM available. The VLI VL805 provides a USB 3.0 Hub via the PCI Express bus. Gigabit Ethernet is provided using a Broadcom BCM54213PE separate from the USB. Wireless connectivity is provided by a Cypress CYW43455 chip, dual-band IEEE 802.11.b/g/n/ac 2.4 GHz and 5 GHz wireless network, as well as Bluetooth 5.0 and Bluetooth LE. The USB-C power connector, the computer requires up to 3 A. The microcomputer has support for two 4K screens at 30 frames per second. Next to the two micro-HDMI ports, there is a 4-pole stereo output and a composite video connector. Storage is provided by a Micro-SD card with a slot on the bottom of the board. The GPIO connector is a standard 40-pin.
Microcomputer
GrabCAD Community will undergo scheduled maintenance on Monday, November 3rd, between 9:00 AM and 3:00 PM UTC. During this time, the website will be unavailable and users will not be able to log in.
