This site has plans for a DIY 3-axis CNC but it should be a decent enough starting point
https://www.diybuilds.ca/shop-project-plans.html
If you add a tilt and rotatable table with clamp then you can achieve 5 axes. :) from there it's just software
Hello if you need Usb cnc controller:
https://www.poscope.com/product/pokeys57cnc/
stepper motor drivers:
https://www.poscope.com/product/postep60-256/
https://blog.poscope.com/stepper-motor-driver/
check also blog site:
this is GrabCad ( engineering portal) and NO facebook and other...
Make some professional thing...
Also only 3 axes but you probably can modify the design.
https://www.v1engineering.com/lowrider-cnc/
Tons of DIY CNC out there.
