hey. I've been chasing this switchblade 300 file for ages and this is the best one I could fine...
the stl of the whole drone can b3 saved as as individual parts, but there are allot of surfaces that I havnt learned enough to confidently turn them into solid parts, would anyone be able to take a look for me and change the surfaces into solid parts for me?
download:
there's also some.alternate files that may or may not fit...... hav wanted to build a working model out of this for a long time, also want to scale it to be fired out of a 40mm launcher
I'd appreciate it so much if someone was able to fix my surface problems... thanks guys and gal*(potentially)
Turbosquid has this one :
https://www.turbosquid.com/3d-models/3d-aerovironment-switchblade-300-1870916
CG Trader has this one :
https://www.cgtrader.com/3d-models/military/rocketry/switchblade-300
MVR Simulation has this one :
https://www.mvrsimulation.com/model/switchblade-300usgrey
Renderhub has this one :
https://www.renderhub.com/3dxin/aerovironment-switchblade-300
Sketchfab has this one :
https://sketchfab.com/3d-models/aerovironment-switchblade-300-539d82faa75b463298328c7095e72aef
Artstation has this one :
https://www.artstation.com/artwork/PeVZQB?album_id=4315565
Yeggi has these :
https://www.yeggi.com/q/switchblade+300+drone/
3D Models has this one :
https://3dmodels.org/de/3d-models/aerovironment-switchblade-300-missile-predator-drone/
this should get you started !!
Also this one is already in phttps://cults3d.com/enhttps://cults3d.com/en/3d-model/various/switchblade-300-by-aerovironment
I've seen every one of them. they r either for video games, are expensive or it's the guy who won't send you the model cause he thinks it's secret military tech that he will only give military officials who always brows cults looking for 3d models that look like military drones. even tho it's the avionics and the warhead that is military tech, not someone's 3d model that looks like a switchblade with nothing inside....
I have a model that can be turned into a printable set of files but I can't get my head around turning those surfaces into solid parts and need someone who's able to do that for me. .
well post you model on your profile with the database and let someone else do it for you.
