Mechanical Engineering
Created by tomas omalley on 14 June, 2018
Yacht Dock Design for rough and variable elevation fresh water lake
Has anyone designed, or seen an effective engineered yacht dock designs for rough water and variable water elevation? Traditional floating docks are mostly used but seem like there has to be a better solution? See attached for detailed description of the problem....thank you!
Rob
Thanks Thomas, will try to post a pdf. Not sure I follow exactly what you mean by 'float volume change' - isn't the float volume fixed by the amount of floatation on the dock?
GrabCAD Community will undergo scheduled maintenance on Monday, November 3rd, between 9:00 AM and 3:00 PM UTC. During this time, the website will be unavailable and users will not be able to log in.
