Hello Daniel! I use SolidWorks for modeling, and for the Keyshot rendering.
Looks very good!
I still have a lot to learn....
Cant pick a my best render as every render you do can have parts that took a lot of work for something complicated or something thats a simple part if I had to put up all my best ones Id probably get it down to 10/15 lol even looking at these before I post I think I should show more....it is what it is
Thank you! But I myself am still a novice in this matter ... I myself do not know much yet. I only use Keyshot for 3 years. Do not despair, it's a long way to life. One of the main criteria for setting the light in the studio and camera angle. The same material can be great in one studio, and completely useless in another studio.
Hello! Do you use in your works, at the final stages of Adobe Lightroom?
No my friend sometimes when adding ies lights you can get spotting,just little tiny spots of light and I will remove those with a photo edit but I try to do nearly everything in the render package,like this render I could have done the prop in Photoshop afterward but figured out a workaround,,,,,,
I added a plane to were the prop would be put a clear material on it and added a png with transparent backround of blurred prop onto the plane this and many things I just worked out with trial and error,just added a quick focal blur to add that flying in the sun look and B&W for the Spit era
Also Autodesk Inventor can attractive render
https://grabcad.com/library/stool-folding-1
Chessmen!! I make these models by Rhino, T-splines. These were rendered by Solidworks PV.
How do you add the "liquid" splash?
How do you add the "liquid" in the first place?
Is it added in the rendering software, or in the design?
In both cases, which rendering/designing software did you use?
Try RealFlow.
You can get a free Dosch Splash Effect Samples over at CG Trader, just choose the best 3D format for your rendering application: https://www.cgtrader.com/items/132210/download-page
The headphones is modeled by my brother and I modeled the lego in catia. Rendering done in keyshot.
2 stroke engine block.Hope you guys like it. A GrabCad model https://grabcad.com/library/2-stroke-engine-block-1
