When designing a pedestal for an industrial robotic arm, how much safety factor do you put into the design? Do you apply the max e-stop rating to the FEA or do you consider you're normal operating conditions? How much do you like to oversize the design? Does anyone do fatigue analyses?
Is that a standard somewhere, or just a safety factor that you're comfortable with? I've been designing with at least 2-3x safety factors. Do you apply all the e-stop forces together on the FEA or do you do one at a time, and look at worst case?
Base your analysis on operating speed/acceleration and required motion accuracy. The pedestal can withstand heavy loads, but the deviations will be on the order of several mm. So if high precision is needed, the pedestal must be massive and rigid.
