Import from Solidworks to Nx
Hello everyone,
It is necessary to continue working with Nx of an assembly file prepared using solidworks (assembly file containing different equipments). I have some problems in this regard.
We bought the models from solidworks with parasolid and opened them smoothly using Nx import. But there is a problem like this. The mass, center of gravity and moment of inertia defined in Solidworks different in Nx for the same equipment. (Maybe I can add same value using weight management again on NX)
In addition, in the technical drawing of the equipment, the axis set appears on the equipment, while the equipment in the model I bought from solidworks refers to the axis assembly of the main assembly. I cannot see the own axis of the equipment in the product tree. What is the solution to this? Is it possible to see the equipment axis set and the main assembly axis set on the screen or in the Nx product tree at the same time?
Thank you.
