I have a step model of a telecom cabinet , which have many hardware having same in subassembly , if i save the assembly then a error appears - " A DOCUMENT WITH SAME NAME IS ALREADY OPEN . VIRTUAL COMPONENTS CANNOT CHANGED SAME THIS. HOW I CAN SAVE
I have a step model of a telecom cabinet , which have many hardware having same in subassembly , if i save the assembly then a error appears - " A DOCUMENT WITH SAME NAME IS ALREADY OPEN . VIRTUAL COMPONENTS CANNOT CHANGED SAME THIS. HOW I CAN SAVE STEP MODEL ALL PART AT ONE CLICK.
try "Save As" the subassemblies first, then save as the top assembly, and before you bring that into your assembly, you may want to replace the duplicated instances with patterns to reduce the loads, once done, I would do "pack and go" just to separate the files actually used from all the duplicates
