Autodesk Inventor 2020 problem with marking menu
When I try to access the RMB marking menu, the menu does not appear below the cursor but way off. This problem started with version 2020, before that I had never any problems. I am running Inventor 2019 as well on the same machine and the menu works fine there. I've got the latest software and drivers. This problem occurs in every environment (Part, Assembly, Sketch, Drawing).
Accepted answer
5 Other answers
Hoi
Maybe you can try to import the setting from version 2019, maybe that works.
Tools - Customize - Marking Menu
Greetings,
Danny
Hi Danny,
Thanks for your reply.
I've tried your suggestion but had no success.
I even tried changing graphics and mouse settings, changed the screen resolution, reset Inventor and reinstalled it but nothing worked. Never had this before, very strange!
Cheers, Hans
Hoi Hans,
I will download and instal Inventor 2020 ,
so I can see how it works on my Pc.
Greetings,
Danny
