Can Anyone please help me to convert an IPT file to STP or DWG?
Thank you in advance.
7 Answer
Follow these steps:
File > Save_As
Then select the desired format which you need.
can anyone please help me to convert an ipt file into step file?
Please convert this ipt file to stp or Step or Stl.
Thanks in advance. :)
Hi,
Your software work for "ipt" file conversation, If yes I've attached ipt file. Kindly convert the attached file
Hi there, good Friday afternoon from Singapore. I have an ipt file which I need to convert to STP file. Can anyone help me?
Hi,
Could someone please convert the following .ipt file into one of either .DXF, .DWG, .STL or .STP?
Thank you in advance. :)
Source: Junction Box
