can anyone solve this question? cswp practice question?
it is all good until question 4. i have no idea on how to find out the thickness of the 2 stick-out area at the top. it seems to me some info is missing. it would be appreciated if anyone can solve this question. thanks!
2 Answer
The CSWP test requires that you work your way through ALL of the exercises starting with Question 1 and then subsequently modifying the ORIGINAL part as required in each subsequent Exercise Question.
Question 4 has many Missing feature dimensions (besides the 2 Tab's Thickness) and are carryovers from the previous Questions Exercises.
Why don't you complete the previous exercises and then throw in a trial value for the Tab Thickness (20mm?) when you do Q4 and see if the MASS is close to that given in the possible answers? Adjust as required....
Hope this helps.
