can someone give me more ideas for making pressure test unit for testing the mechanical seal leakage prior to install it
Create a modular test chamber that can accommodate different sizes and types of mechanical seals. This allows for flexibility and scalability in testing various seal models
Install high-precision pressure sensors to monitor and record pressure changes within the test chamber. This helps in accurately detecting even minor leaks.
Implement an automated system to control and adjust the pressure within the test chamber. This ensures consistent testing conditions and reduces human error.
Incorporate a transparent section in the test chamber or use cameras to visually inspect for leaks. This can be combined with dye penetrant testing for enhanced detection.
Use a data logging system to record pressure, temperature, and leak rate data over time. This data can be analyzed to assess the seal's performance and predict its lifespan.
