Change text size based on other parameter
Hi Guys,
I need to be able to change text size based on another parameter. Sketch size unfortunately is not a parameter so it is not easily changed.
If this is going to be cut or engraved you can extrude new bodies at some base size, then scale (parameterized), then use them as tool bodies to subtract from your target body.
