How can I display Sketchup (.skp) files?
When I uploaded a model it does not show the model
2 Answer
From Hardi Meybaum
you can create a Print Screen and then it will show your file.
You can also export whatever you see onscreen by going to File > Export > 2D Graphic. When the window pops up you have the options to set the file-type and resolution of the exported image.
