How do we create an ellipsoid (with different minor axes) in catia?
Hi friend, maybe you can try, to add two points and get the dimensions between two points, and select the dimension that you want, after that, you click in the ellipsoid icon and click in the differents point, that you added them.
If that dont work, just send us an picture or printscreen that will be more easy, to understand your issue.
Have a good day,
Best Regards,
