how enable automatic spur gear command on in solidworks
Step 1: Enable Toolbox Add-in
1. Open SolidWorks.
2. Go to Tools → Add-ins.
3. check SolidWorks Toolbox and SolidWorks Toolbox Browser in the Add-ins window.
4. Click OK.
Step 2: Open Toolbox and Insert Spur Gear
1. Open a new Assembly or Part file.
2. Go to Design Library on the right side of the interface.
3. Click on Toolbox → ISO Standard → Power Transmission.
4. Open the Spur Gears folder and select the appropriate gear.
5. Drag and drop it into your model.
How to Enable Automatic Spur Gear Command in SolidWorks
To enable and use the automatic spur gear feature in SolidWorks, follow these steps:
1. Enable SolidWorks Toolbox & Add-Ins
Open SolidWorks.
Go to Tools → Add-Ins.
Enable:
✅ SolidWorks Toolbox
✅ SolidWorks Toolbox Browser
Click OK to apply changes.
2. Insert Spur Gear from Toolbox
Go to Design Library → Toolbox → ANSI Metric or ISO → Power Transmission.
Select Spur Gears.
Drag and drop the gear into your assembly.
Set parameters like module, number of teeth, and bore size.
3. Use the Gear Mate (Automatic Motion Command)
To enable automatic gear rotation:
Go to Assembly Mode.
Select Mate (Insert → Mate).
Under Mechanical Mates, choose Gear Mate.
Select the two gear faces and set the gear ratio.
Click OK.
Now, rotating one gear will automatically rotate the other based on the defined ratio.
4. If Toolbox Is Missing?
Go to Tools → Options → System Options → Hole Wizard/Toolbox and ensure the correct file path is set.
If Toolbox is not installed, you may need to reinstall SolidWorks with Toolbox support.
