How to add equations in parametric modeling in SolidWorks 2023 Premium?
I must avoid designing the same model for number of times where one or two parameters change. By just changing the parameters, The same model should change.
Accepted answer
In parametric modelling you can add equations using = sign next to dimensions. One thing to note that already those equations should be defined. The most common example of using equations in parametric modelling is gear design. In case of references see how gears are designed using equations,
I hope your query is resolved.
