How to add the Progressive Die Extension in Creo parametric 2.0?
Are you able to log into PTC and see the extended view?
https://support.ptc.com/apps/solution_preview/solution/lang/presolution?lang=en&n=CS69691
____________________________________________________________
Here is a preview of what it contains:
Title
How to start Progressive Die Extension within Pro/ENGINEER or Creo Parametric
Description
•How to start Progressive Die Extension(PDX) within Creo Parametric
•How to launch Progressive Die Extension(PDX) within Pro/ENGINEER
•How to install PDX
Applies To
• Progressive Die Extension 6.0-7.0 all datecodes
• Pro/ENGINEER Wildfre 4.0-5.0 all datecodes
• Creo Elements/Pro 5.0 all datecodes
• Creo Parametric 1.0 all datecodes
