how to calculate turbocharger turbine performance in ansys fluent software?
i have designed a 3d model of turbine and its volute of a turbocharger using catia.
i want to calculate the performance or if i can know the rpm of turbine if i give the boundary conditions like temperature,pressure and mass flow rate at the inlet of volute how can i do this?
Maybe that file will help you?
Did you solve your problem??? If yes, let me know, I've got the same problem.
Thx a lot for this software, Do u know if there is a software which create cad model from some input data?
