how to change the default units inches into mm in solidwork
Step 1 :- Open a New Part File in Solidworks
Step 2 :- Now click on Options
Step 3 :- Now check under Document Properties & click on Units
Now change the default Unit system to your desired unit system
Step 4 :- Next step is to click on Save button
Step 5 :- Now change the file Save As Type to Part Templates
Step 6 :- Now click on the Original Template File & press Save
So now you have PERMANENTLY changed your Unit system
Note that the similar procedure is also applicable to Assembly and Drawing Files...
very easy, go to options on the main toolbar select document properties tab -select units from the drop down menu - click on unit type and set number of required decimal places etc. I normally set them to 4 places of decimals
