how to change the title block in drawing sheet & also how to edit the bill of material
i dont kno how to set the sheet format like a4 ,a3,a2..... in sw 2009 and then how to change title block as 1st angle projection 3rd angle projection ?
while i creating the bill of material its showing ly the name of file name &
Qty but i cont edit the description, weight , siZe......
pls bro help me?
Hopefully this PDF I made quickly helps. Covers sheet properties, title blocks and BOMs.
If you want to start from scratch, open up a blank drawing. Over in the design tree, right click "Sheet 1" and select properties. The window that pops up will help you set many of the options you're asking about. Type of projection, sheet sizes and scale are available in here.
I beleive basic Solidworks sheets are set up so that if you fill in the custom properties in the actual part, the title block will autofill on the drawing. If this is not so, you can do this yourself.
NX
How to Automatic updated/Process in drafting. Mass, Drawing Name, Date, Sheet.
In NX sheets are set up so that if you fill in the custom properties in the actual part, the title block will autofill on the drawing. If this is not so, you can do this yourself.
