How to convert obj. format scanned file to iges. or step. format. using geomagic wrap
i have scanned file of obj. format. i need to open it creo3.0. so need to convert to it to Iges. or Step. file format. I gave Geomagic Wrap . i need your help to convert it.
i can convert is as a surface. but i need surface and some line of scanned surface. i cant export both of surface and line simultaneously using Geomagic Wrap.
so need your help.
I have attached some picture of scanned profile.
Thank you
U have obj file
U can open it in creo 3.0
If u can't open it
This may not work all the time but give it a try
If suppose the file name is CABIN.OBJ
Rename it as CABIN.STL
now try to open it or import it
ishara dissanayake 2 Mar, 2021 04:22 PM thanks Dread. but although .Obj open in creo its open as mesh modle. but my need is use this scann file as a surface for creo. there for i need to convert obj file in to surface modle via geomagic wrap
