How to convert step or x.t files to solidworks assembly?
Hello, I want to ask if I can convert those files to a folder that contains the parts, so I can open the parts directly and edit them ?
Converting STEP (.STEP/.STP) or Parasolid (.X_T) Files to a SolidWorks Assembly
When you import STEP or X_T files into SolidWorks, they usually come in as a single solid body. To properly convert them into an editable SolidWorks assembly, follow these steps:
Method 1: Direct Import (Basic Method)
Open SolidWorks.
Go to File → Open.
Select the File Type:
Choose **STEP (.step, .stp) or Parasolid (*.x_t, *.x_b).
Click "Options" (Before Opening):
Check "Import multiple bodies as parts" to break the model into an assembly.
Set "Assembly Structure Mapping" to define how bodies are treated (Parts vs. Assemblies).
Click Open – The file will be imported as a SolidWorks part or assembly.
Method 2: Converting to a Proper Assembly
If the imported file is a single part file, convert it into an assembly:
Step 1: Convert Multi-Body Part to an Assembly
Open the imported STEP/X_T file.
Check the FeatureManager Tree:
If it contains multiple solid bodies, proceed to step 3.
If it’s a single solid body, you may need to use "Split" (explained later).
Go to Insert → Features → Recognize Features (optional for feature recognition).
Save the File as an Assembly:
File → Save As → Select Assembly (*.sldasm).
Choose the option "Save each body as a part".
Method 3: Using Split Command (If Needed)
If the file imports as a single solid body, split it into individual parts:
Open the STEP/X_T file.
Go to Insert → Features → Split.
Select Cut Planes to separate bodies.
Click "Cut Part" and select "Save Bodies".
SolidWorks will create individual part files, which can then be assembled.
Method 4: Using Assembly Structure Mapping (Advanced)
When opening the file, click "Options".
Under Import Options, choose:
"Import assembly structure from file" to maintain part hierarchy.
"Import as SolidWorks Parts and Assemblies" for easier editing.
Final Adjustments
Mate the Components: If needed, use Assembly Mates (Insert → Mate) to align parts properly.
Apply Materials & Colors: Improve visualization by assigning materials.
Check for Errors: Use FeatureWorks (Tools → Features → Recognize Features) to convert geometry into editable features.
