How to convert surfaces to solid bodies in SolidWorks?
I draw something with surfaces module on SolidWorks and i want to make it thick as a solid body and to use features on the design. I can't use "thicken" command to all the surfaces. Is there any easy and fast way to do it?
Hi Cemal,
I think I interpreted your question correctly, if not let us know.
If you have a lot of surfaces you can Knit (Insert > Surface >Knit) them together then thicken will apply a thickness to all the surfaces at once.
On the other hand if you have surfaces that create a closed body you just Knit all the surfaces together to make it a solid, as long as the surface edges are within a nice tight tolerance and there are no holes/gaps.
