How to create realistic water islussion
Hello ... i m going to create rendering of a ship in keyshot 4 and i want to put it into water ... do u have tips and trics how to make water realistic as much as its possible ? and airspace ? Thank u
Please look into my projects. There is one that is called experiments with water. It my help you get a good start.
Kamyar
Ondrej,
Download the textures and experiment. Sowing realistic water and waves is very limited if you use mechanical engineering software.
The light source is the "environment". assign "liquid" for your water. Also you must increase the size of your environment. If the environment is a typical room, 4x5 meter, and your water is 100 or 1000 meter wide, the little room and its lights can't show anything.
