How to determine curvature radius using nx?
I need to calculate a curvature radius of this surface between 100mm x and y using nx..How can i calculate this radius using this points?
6 Answer
There is not enough details in the attached image
If you cannot calculate it, and to save modelling time, You can put the same image as a reference background in the design software and trace over it to draw the satisfactory curvature.
https://grabcad.com/tutorials/is-there-anything-like-tracing-2d-image-to-model-in-siemens-nx8
Hi,Auday
the above image is not 2d its 3d curved surface...i need to find a curvature radius for every 200x200 portion,on the surface itsself ..so i need that thing.
If it is 3D you, then you still don't have enough data to get the 3d curvature, maybe I got it wrong!
