How to edit CATIA file format in Autodesk Inventor 2013 or Fushion?
I have get CAT file from my customer and need to use the part for lower die and upper forming punch block..Please help me solve the problem..
2 Answer
You can try to follow the same basic idea that I outline in my answer to your other question.
http://grabcad.com/questions/how-to-extrude-to-next-using-cat-file-in-inventor-2013
There are some free ONLINE courses for Fusion at http://www.myigetit.com
Fusion would probably be the best solution you could create a part for each station in the progressive die.
Good luck!
Hi Faisal I am not to sure you can edit the Catia part in IV as it will still come in as a 3rd party part.... Hmmmmm
Hahaha thank you for this question as it has now giving me a little bit of education I did not know about after I had to do a little bit of reading up there.
:P
http://autodeskmfg.typepad.com/blog/2009/09/working-with-catia-data-in-autodesk-inventor.html
