how to make new pattern according to our need in assembly without re using the patterns? Ravichandran 6 Dec, 2012 02:57 AM without using re using pattern of 2nd part we should pattern our 1st part itself according to our needs. 2 Answer sundaram Answered on 22 Dec, 2012 05:43 AM In assembly, module...... we need the dimensions to make the assembly.... unless we can't do that in CATIA 418ab476 Answered on 15 Mar, 2013 12:20 PM why don't you insert same component again.. if you dont want use pattern in assembly.. you can insert again the same component . and place it where ever you want..
