how to model a laptop table(cooling fan) in autodesk
For the legs you may need to do a 3D sketch and for the hinges you will just need to make the parts separate and put them into an assembly. For the fans create the different points you ill need to connect from the side. Loft or sweep the fan parts through separate sketches in order to create the shape that you will want.
Feel free to message me if you have any more questions.
