How to move an sub assy up in the tree with other sub assys in SW
I can drag an item in the tree of SW any where I want as long as it isn't an assy or if the part is going next to a sub assy.
If I drag it next to a sub assy it thinks I want it to be apart of that sub assy.
It's the alt key. If you alt-drag the part over the assembly name, you will see the icon change to an arrow just like you see when reordering parts.
If you hold a key while draging, it will move the selected assy. That assy will stay at the same level. If my memory is good, it is ctrl or is it alt?
Thanks guys it works. It is the "ALT" key.
