How to program in autodesk inventor
I would like to create a program or a macro that I can run in autodesk inventor and create views of material given a set of two inputs. As an example, I want to be able to create a view of a block from its center plane (so it would be a cut view), and one sides length (to create the views size from). This second setting I would like to be able to adjust as needed. Currently, I am doing all of my work in autocad as it is easier to create specific views of features, but if I could work out a way to allow me to easily create feature views in inventor I could utilize it to its full potential.
Hi brandon,
Best is to use vba ; only press Alt + F11 in inventor .
Then start your codes .
For more information ; please take a look to :
http://modthemachine.typepad.com/my_weblog/2008/09/index.html
Good luck
