How to trim or remove this exessive line??
To trim or remove excessive lines in GrabCAD, you can use the editing tools available in the platform's 3D viewer. Follow these steps:
Open the GrabCAD model in the 3D viewer.
Look for the editing tools located in the viewer's toolbar or menu.
Select the "Edit" or "Modify" option to enter editing mode.
Choose the specific editing tool for trimming or removing lines. It may be labeled as "Trim," "Delete," or "Remove."
Use the editing tool to select the excessive lines you want to remove.
Confirm the deletion or trimming action to remove the selected lines from the model.
Exit the editing mode to finalize the changes.
Regards,
Rachel Gomez
