IGES file imported in Creo assembly it shows only tangent constraint..?
Hello,
In Creo parametric while importing IGES file to assembly the only constraint I get is tangent constraint. Pl help me some solution to solve this problem or Is there any other method to use IGES file in assembly with all assembly constraint(coincident, distance, parallel, oriented, etc).
Thank you,
Dina.
Hello,
the correct way to go in this situation is open a new session > import the iges file then save the same file as a part (.prt) then use it in other assembly where you are getting this error.
