In CATIA V5 drafting workbench, how to create an isometric view with colors?
Hi
If you select the properties of the ISOMETRIC VIEW you'll find two tabs: Graphic and View; select View. After that you have the "3D Colors" option. Also in the "View generation mode" select RASTER.
Cheers!
Near RASTER you have the OPTION button. Use this command to choose what type of image you want (I personally use "shading with edges"). Also you can set the quality of the picture.
