Is it possible to print one object in two colors?
Hello,
i want to print one object in two colors, the gradient should be clear defined.
Is it possible to define the gradient with the Grab Cad print software?
The object is a dental prosthesis with pink and white color.
Printer: Stratasys J5
Thank you :)
  • Fruqan Hamid
    Fruqan Hamid 20 Mar, 2025 05:24 AM
    Yes, it’s possible to print a single object in two colors using the Stratasys J5, but the gradient transition depends on the printer's material settings. In GrabCAD Print, you can assign different materials to specific regions of the model, but for a smooth gradient, advanced color-mixing features or manual design adjustments might be needed.
You need to turn off the extruder flush when changing colors and then the gradient will be smooth.
Upvote 0Upvoted 1 Downvote 0Downvoted 1
