Is there a Solidworks macro to knit all surfaces and create a solid?
Hello,
By any chance, do you know a macro than can knit surface all together and create a solid, and works even when the file is composed of several multibody at the end?
I often have to used third partie softawre to design stairs and save as Autocad 3D.
When I imported it, I have to knit all stairs one by one, and that's a very heavy time consuming.
One macro than knit all stairs to itselt will be a must.
Solirdworks should knit the stairs by itself during the DXF import, but that not the case! Thanks for your help.
Hey,
just completed the first full test run with your TestFullStairs file. It took about 2 minutes to iterate through all parts. So here's a quick description of what it does in particular:
- creates an internal list of all parts in the assembly
- iterate through that list
-- open the currently listed part document
-- iterate through the design tree of that part document
--- if the current feature is a surface feature, add it to the selection manager
-- by reaching the end of the design tree, create a surface sew feature if the selection is not empty (this is the case when the part contains at least one surface feature)
-- save the current part document silently
-- close the current part document
You can choose from a bunch of presets:
It's possible to toggle
- "Include Subassemblies" -> include all part documents in any present subassembly
- "Use Gap Filter" -> activates the gap filter by SolidWorks
- "Try to Form Solid Body" -> SolidWorks will try to create a solid body if enabled
- "Merge Redundant Entities" -> SolidWorks will automatically merge edges and faces by removing redundant edges and vertices
and to set a value of the datatype "double" for
- "Knit Tolerance" -> from 0.0001 to 0.1 mm
- "Maximum Gap Range" -> from 0.0001 to 0.1 mm
