Need help with SolidWorks API functionability
I am currently working on a VBA program that will automatically sketch cursive fonts, dissolve them, then extrude them. So far I have been able to extrude every contour but am struggling to be able to tell Solidworks which contours to not extrude (i.e. the contours inside a lower case "e")
This has to be functional for every letter and possibly different cursive fonts.
Also, my next challenge will be finding a way to place mounting holes in the appropriate spots.
If anyone can offer any insight it would be greatly appreciated.
Is there a way to choose a profile/contour by its area?
Outside of that I don't think there would be a solution, especially one that would work for different fonts.
When working with cursive fonts, I always found lots of trouble once they were dissolved. Little loops and intersections seem to plague cursive fonts. There was almost always a need to go in with the trim tool to clean up the sketch before it could be used for a feature.
Here's an idea: just sketch the centerlines of the fonts, and add the thickness when you extrude them with the Thin option. Bold fonts would have a larger thickness.
I tried my idea and I'm not too thrilled with the results:
Yeah and with cursive you wouldn't get the different sized portions of text. We have actually been able to get the extrusion corrrectly and now just have to find a way to add two mounting holes.
I am thinking of modifying a font and building mounting holes into letters and programming it to only use the letters with mounting holes at the beginning and end of the word.
