Saved Design Accelerators - Bolted Connection not opening in others system.
I have create 4 difrent bolted connection through 'Design Accelerators - Bolted Connection' and saved it in the design acceleators template (in my system project path). But when i am opening the same model in other system the bolted connection file are shown missing. After that from model tree i have to regenarate the bolted connection again, and then it is opening.
Kindly solve the proble.
I think the problem is that the da creates uses center parts for screws, washers, nuts, ...
These parts only exist on the computer where they was created and not one the second computer too. So try to copy your template and the approbriate content center files.
Alternatively you can act the same way as before and regenerate your template on the second computer, This creates the necessary content center files on the second computer but the newly created files are not identical with the files from the first computer (except geometry)
