Tutorial - 2D Truss analysis in Mechanical APDL (ANSYS) Part 2?
Tutorial on two dimensional bridge truss analysis in ANSYS 13.0.
    In general, a finite element solution may be broken into the following three stages.
    1. Preprocessing: defining the problem;
    - Define keypoints/lines/areas/volumes
    - Define element type and material/geometric properties
    - Mesh lines/areas/volumes as required
    2. Solution: assigning loads, constraints and solving;
    3. Postprocessing:
    - Lists of nodal displacements
    - Element forces and moments
    - Deflection plots
    - Stress contour diagrams
    In this tutorial we will go through second and third step.
    Answered with a tutorial: https://grabcad.com/tutorials/tutorial-2d-truss-analysis-in-mechanical-apdl-ansys-part-2
    Upvote 10Upvoted 11 Downvote 0Downvoted 1
      I have too many keypoints for a truss. Can I define them in an excel sheet and then import it to APDL? Can I do that?
      Upvote 0Upvoted 1 Downvote 0Downvoted 1
        Tutorial - 2D Truss analysis in Mechanical APDL (ANSYS) Part 2?"
