Tutorial: How to use rib feature in Autodesk Inventor?-Lesson 2
5 Answer
Neither one of these is a good execution of the Rib command, both of these tutorials could be done with the extrusion command. Try a rib with this guy to get an idea of where you should be using Ribs.
Tutorial to use rib feature in Autodesk Inventor?-Lesson 2
Answered with a tutorial: https://grabcad.com/tutorials/tutorial-how-to-use-rib-feature-in-autodesk-inventor-lesson-2
