Which is the best way to move a part along the X Y Z axis by a specified dimension?
I'm looking to move a part along the XYZ axis to show the movement of this part in various ways. I have tried to translate but this way is a little messy and ideally I'd like to quickly see the changes.
e.g. move 'Part1' 0.5mm along X axis - then move 'Part1' -1mm along Z axis
Thanks!
Translate command is good for this. But if you dont like it, you will use "Axis System" command.
Here is the tutorial.
Answered with a tutorial: https://grabcad.com/tutorials/which-is-the-best-way-to-move-a-part-along-the-x-y-z-axis-by-a-specified-dimension
dear take a point and make an axis system on that point and after that make part and give every dimension to that axis only and rotate or translate whatever u feel like ,it will go.
Thanks for the information!
But my Body is a collection of just isolated surfaces. Can I constrain these surfaces to the axis system I create?
