3D Printing Design Guidelines
~ 9 Steps to consider while design for 3d Printing.
Step 1: Wall-Thickness
A minimum wall thickness of 1 mm.
The walls of larger parts need at least 1.6 mm thickness.
Step 2: Design for No-Support: - 45 Degree Rule
Overhangs that are greater than 45 degrees will need support or you need to use clever modeling tricks to get the model to print.
Step 3: File Resolution
consider while converting .stl file.
~ Fine
~Coarse
Step 4: Clearances
1) Right Space between Moving Parts: We advise you to keep a minimum space of 0.4 mm between designed surfaces.
2) Assembly: Always leave at least 0.3 mm between the different parts.
Step 5: Shrinkage
General Shrinkage is 0.1% or ± 0.2 mm, which one is greater. (consider while designing.)
Step 6: Embossed and Engraved Details
For engraved text or surface details, we recommend letters with a minimum line thickness of 1 mm and a depth of 0.3 mm.
For embossed text and surface details, we recommend letters that have a line thickness of at least 2.5 mm and a depth of at least 0.5 mm.
Step 7: Holes
When tight tolerances are required, either the holes in the model may be oversized or they may be drilled later. For example to get a 5mm hole it has to be designed with 5.3mm diameter. For holes up to 10mm in diameter you can add 2% to 4% correction and smaller for bigger diameters.
Step 8: Fillets
It help reduce the stress during printing and strengthen the part.
Step 9: Threads
When designing threads avoid sharp edges and 90 degrees angles as they can be stress concentrators in plastic parts. ACME threads (as shown on the pictures) are found to work well with FDM, so this is the recommended type. Recommended minimum size of the thread is 0.8mm
doy gracias al creador de la guía y al google translator por una traducción del 99% eficaz
superb article. Because if i create a hole in design after printed it was entirely different like if a hole is 5.0mm means output is 5.3 or 4.8. Now i got a solution for that problem through your tutorial.
thank u Ananthakrishnan Balasubramanian
good !
Thank U song
This comment was removed
Brilliant, small tips make a huge difference in final part print printing.
Thanks, I agree
Great tips, exact values I´ve used in my designs. Good job !
thank u SO much for support.
paulo
Henk Diepeveen
Nathan Tester
Great tips guys!!! Thanks a lot!!!
Thank u Sergey Vishnyakov
Thanks for this very usefull tutorial.
I am trying to print wings for small rc airplanes, wiith span < 2 m.
To compete with current construction solutions ( balsa wood, foam, depron) i need to build thin walls with 0.2 mm.
Is it possible to do that using current 3d printing techniques?
Vielen Dank
Great, thanks for sharing all the steps in detail..
