AutoCAD - Complete Tutorial for Beginners - Exercises 25
COMPLET COUESH FOR 100 EXERCISEC
FUNCTION KEY:-
Ø ESC : To cancel Command
Ø F1 : Autocad Help
Ø F2 : Text Window on/off
To see recently used command, options, Points.
Ø F3 : Osnap button on/off.
Ø F4 : Tablet on/off (Autocad 2010 & Prior Versions)
3DOSNAP ON/OFF (Autocad 2011 & Autocad 2012)
Ø F5 : To change isoplane in isometric drawing.
Ø F6 : DUCS (Dynamic user co-ordinate system) button on/off.
Ø F7 : Grid button on/off.
By default grid spacing is 0.5 inch in X- direction and Y direction.
Ø F8 : Ortho button on/off.
Ø F9 : Snap button on/off
If snap button is on mode from status bar than cursor
will be Jump on the graphic one dot to another dot.
Ø F10 : Polar button on/off. (Alternate off ortho button)
Ø F11 : Otrack button on/off. (object snap tracking)
Ø F12 : DYN button on/off. (Dynamic input)
Short cut keys:-
Ø Ctrl+A : select all
Ø Ctrl+B : Snap on/off
Ø Ctrl+C : Copy objects to clipboard
Ø Ctrl+D : Dynamic UCS (DUCS) on/off
Ø Ctrl+E : To change isoplane in isometric
Ø Ctrl+F : Osnap on/off
Ø Ctrl+G : Grid on/off
Ø Ctrl+H : Set variable
Ø Ctrl+I : Co-ordinate on/off
Ø Ctrl+J : Repeat Last Command
Ø Ctrl+K : Hyperlink Command
Ø Ctrl+L : Ortho on/off
Ø Ctrl+M : Repeat Last Command
Ø Ctrl+N : To create new autocad file
Ø Ctrl+O : To open autocad file
Ø Ctrl+P : To print/plot autocad file
Ø Ctrl+Q : To Quit/Exit from autocad
Ø Ctrl+R : To cycle between viewports
Ø Ctrl+S : To save autocad file
Ø Ctrl+T : Tablet on/off
Ø Ctrl+U : Polar on/off
Ø Ctrl+V : Paste objects from clipboard
Ø Ctrl+W : Otrack on/off (Autocad 2010 & prior ver.)
Ø Ctrl+W : Selection cycling on/off (New Autocad 2011)
Ø Ctrl+X : Cut objects to clipboard
Ø Ctrl+Y : Redo
Ø Ctrl+Z : Undo
Ø Ctrl+0 : Clean Screen
Ø Ctrl+1 : Properties
Ø Ctrl+2 : Autocad design center
Ø Ctrl+3 : Tool Palettes
Ø Ctrl+4 : Sheet set Manager
Ø Ctrl+5 : Info palette ( not working from Acad2008)
Ø Ctrl+6 : Database Connect
Ø Ctrl+7 : Markup set manager
Ø Ctrl+8 : Quick calculator
Ø Ctrl+9 : Show /Hide Commandline Window
Ø Ctrl+Shift+C : Copy objects With basepoint
Ø Ctrl+Shift+E : Presspull Command
Ø Ctrl+Shift+H : Show /Hide Commandline window
Ø Ctrl+shift+P : Quick properties
Ø Ctrl+Shift+S : Save as Autocad file
Ø Ctrl+Shift+V : Paste as block
#Complete Tutorial for Beginners
#AutoCAD
- SolidWorks Beginners Tutorials
- SolidWorks Sketching
- SolidWorks Surface
- SolidWorks Weldments
- SolidWorks Assembly
- SolidWorks Drawing
- SolidWorks Sheet Metal
- SolidWorks Mold Design
- SolidWorks Simulation
- SolidWorks Motion
please subscribe our channel for more videos & projects in solidworks & dont forget to hit like & share the videos, thanks for watching.
CADCREATIVE.IN
Laptop Information
Dell G3 3579 Core i5 8th Gen 15.6-inch FHD
Item model number - G3 3579
Processor Type - Core i5
Processor Speed 2.3 GHz
RAM Size - 16 GB
Graphics Coprocessor - NVIDIA GeForce GTX 1050
