Create Bevel Gear in Autodesk Inventor
Create Bevel Gear and make animation with Autodesk Inventor
Step 1: Create assembly object
Save the file
Step 2: Using Bevel Gear Generator to create gear
Open Bevel Gear Generator (Design -> Power Transmission -> the arrow at Gear icon -> Bevel Gear)
Click double arrow to open all box
Choose "Gear Ratio" (or "Number of Teeth")
Choose "Module" of gear (or "Diametral Pitch")
Input factor number (Gear Ratio, Module, Face Width,...)
Click Calculate (if need) and click OK
* If you need change more information as force, torque, material,... you can change to Calculation tab.
Step 3: Create animation
Contrain axis of each gear with fixed axis (Z with Z axis of active gear-bevel gear1, Y with Z axis of inactive gear-bevel gear2)
Enable Flexible option for Bevel Gear
Make angle contrain between active gear and a fixed plan (that was created at previous step)
Can follow below video to contrain it:
Open Diver (Angle of above contrain), input factor and run animation
