Designing Approximate Spur Gear in CATIA V5 (Method 1 of 4: manual input)
This BND TechSource video shows how to create a “template” part for an Approximate Spur Gear.
This part may be modified by simply changing the parameters of any/all of the following three formulae:
1) z - number of teeth // real parameter [z = input]
2) Rpa - Ref Pressure Angle // angle parameter [Rpa = input]
3) m - module // length parameter [m = input]
Next we will look at using Design Table (from MS Excel) to feed the parameter data and update the Spur Gear.
