Door handle with texture
This tutorial is going to show the main steps on how to apply the relation to the 3d model. wish it could be helpful.
Step 1: Create the handle surface
Step 2: Create a variable helical sweep surface interset with handle surface
Draw a funtion graph.
Sweep a normal radiative surface along the handle center curve.
Type the funtion relation.
Now you get a variable helical radiative sweep surface.
Step 3: Create the intersect curves
Create the intersect curves between handle surface and sweep surface.
Also connect the end curves.
Complete the curves like this.
Step 4: Create sweep texture slots
Create slot surface one by one.
Merge all texture slots.
Step 5: Final step
Solidify the raw handle surface.
Cut the solid handle with textrue surface.
